do OSD skin support unicode ?
adrianmak
DVBViewer 4.3.x is getting full support in unicode :)
I have a non-English OSD skin (chinese). OSD screen chinese text will show rubbish chars in DVBViewer 4.3.x
I look into the OSD xml file I found it the xml lang encoding tag is ISO-8859-1
Is it possible to use UTF-8 encoding tag in OSD xml file ?
I changed the tag to UTF-8 and save xml file in UTF8 text encoding without BOM but the chinese text still not display properly
Edited by adrianmak
