DVBT USB on Windows 7
shr2k4
First of all I am new in this area, so consider any mistakes lightly :(
I used DVBT USB Dongle on XP and then on Vista Ultimate using its own driver and viewer without any problem.
Today I installed Windows 7.
  • The driver of the Dongle installed without any problem
  • The DVBViewer which came with its own CD also installed properly
  • But when I try to run the viewer it shows in an error window that Avcapture MFC application stopped.
  • Tried to reinstall both but the result is same
I use USB dongle to watch TV and only for it I might need to go back to either XP and horrible Vista.
If any one has any solution before I go back, please let me know.
Note: The USB dongle is an unbranded dongle which came with its own driver and viewer in a small CD.
Thanks
Try to rigth click the Viewer application shortcut, chose compatibility, chose run this program as, chose windows Vista, or maybe XP.
The above words could be wrong, because i run a Danish version of Windows
