DVBViewer can't maximize after screen resolution changes
ter9999
64-bit Windows 7. EVR or EVR Custom. ATI catalyst 9.9. All 4.x.x.x versions of DVBViewer.
When DVBViewer is in window mode, if the screen resolution changed, then the DVBViewer can't be maximized by double-clicking. After the double-clicking, the menu and status bar will disappear. Need to close and re-open DVBViewer to allow maximize.
This phenomenon also occur when I turn on the 2nd display (HDMI TV in my case). No matter leave DVBViewer to my 1st display or drag to the 2nd one, it can't be maximized neither.
Please check.
I can confirm this, yes. Never reported this however because I thought that I have more free time to spend on restarting the application than Lars to debug this :( .
Edited by CiNcH
This issue will impair user experience when using 2 monitors (TV as the 2nd monitor), because TV will often be turned off/on for power saving purposes, every time after the switch, DVBViewer won't maximize, need to close and re-open....
Anyway, hope this bug can be fixed if authors have spare time.
Here is what the issue looks like:
There will be blank and white stripes at sides and no main DVBViewer window frame at all. Need to close and reopen, very annoying, will experience worse when in timeshift.
Easy workarounds to get maximization after this:
1. resize the window.
or
2. right click the signal strength bar in DVBViewer status bar to call out "DVB Source Properties" window (new feature in version 4.3), then it will okay to double click to maximize.
Hope the issue be fixed...
Edited by ter9999
