XMLTV tool
balky
Is anyone able to recommend an XMLTV tool that works with the DVBV XMLTV importer?
I will prefer a tool that I can download, PAY a license fee, install and work from a GUI.
I don't want to create batch files or create windows system services, or perl scripting or any geeky stuff that will take long plus hardtimes to correctly setup.
I just want to pay a fee install and keep it simple
Thanks.
Thanks Tjod,
I basically want EPG for UK FTA and Belgian stations in english (if possible)
Thanks once more.
Thanks Tjod,
Thanks once more.
I have installed the tool from the link above and I am still as confused as ever... :-)
Where can I find the TVData.xml? where can i find a working grabber for Belgian and UK stations? where can I find the TVGGV2.exe?
How do all these pieces join together?
A million thanks for your help...
