DVBviever / Mediacenter installation / DVBLink
Per Raebild
I have a problem - have tried to install 2 TechnoTrend DVBC budget TT-C1501 at my Vista Mediacenter
I was advised to use DVBLink and have followed the instruction 100%, DVBViewer scan channels and all available channels works fine.
After installing DVBLink, DVBViewer starts hanging and slows down the computer very much - (i have stopped the service DVBlink server).
Im using DVBViewer pro edition 4.2.1.0 and DVBLinkServer + DVBLinkDV available at http://www.dvbsbridge.com/DVBViewer.php
Further more i have tried a complete new installation of both Windows Vista Ultimate + Windows7 64bit, no matter what i do the system ends
up hanging.
Is anybody recognizing this problem, i would be very grateful to have a hint about what to do?
Best regards Per Ræbild
Edited by Per Raebild
  • 4 weeks later...
I'm having the same problem, TerraTec Cinergy C PCI HD card, DVBViewer and DVBLink for Vista Home Premium - followed the instructions completely...
Does anybody know how to work around this?
Forget DVBLink, dump Mediacenter and (almost) everything will work fine.
Not very helpful. I'm not asking your opinion about VMC and DVBLink, but about help configuring this. If I were to dump VMC and DVBLink, it would be for MythTV, not DVBViewer standalone.
Did anybody find a solution?
