Tuning problem with DVBviewer 4.2.1
WBMK
Hi All,
I recently bought DVBViewer, and i am trying to get in to work on my system. But when i try to tune a DVB-C channel (FTA). DVBViewer display's a 'flickering' image. Every second it switches from displaying a good, clear picture to a black screen. I tried numeroes combinations of codec's (Nvidia Purevideo, coreavc, ffdshow, powerdvd9) with renderer's (EVR, VMR7, 9 with or without Nvidia Fix).
Now i found out that when i enable the PIP mode (when using the default Microsoft DTV codec and EVR renderer), DVBViewer display's the channel correctly and i can switch channels correctly. I can even disable the PIP function and continue to watch the channel. But when i restart DVBViewer i get the same problem.
I attached my support.zip and i am using the following configuration:
P4 2,8 Ghz
2 Gb RAM
Asus P4T800 mainboard
Geforce FX 5900 graphicscard
Terratec Cinergy C HD PCI tuner board
Windows 7 RTM 32 bit
Default mainboard drivers that come with win7
Default graphic driver for win7 (forceware 96.85)
Terratec C PCI driver 1.1.0.601
Thanx in advance
