peon Posted October 12, 2009 Posted October 12, 2009 Hi, Well ive have a quick question.. Ive remember in previous versions of DVBViewer that when on timeshift it records the whole live feed from when you start the program till you end it. But this i dont see in the newer versions. When i change channel now it deletes the previous timeshift on channel and starts a new for the new channel. Question: Is it possible to make one big timeshift channel that contains all the channels ive watched until i quite the program? /Erik Quote
erwin Posted October 13, 2009 Posted October 13, 2009 Question: Is it possible to make one big timeshift channel that contains all the channels ive watched until i quite the program? Look here: http://www.DVBViewer.info/forum/index.php?...st&id=20366 and here (but in german language only): http://www.DVBViewer.info/forum/index.php?...st&p=234062 and here for a short english description: http://www.DVBViewer.info/forum/index.php?...st&p=260289 If you timeshift across different channels there are problems if audio/video-format is changing. mfg erwin Quote
Griga Posted October 13, 2009 Posted October 13, 2009 If you timeshift across different channels there are problems if audio/video-format is changing. ...and PIDs are changing, as in most cases. Therefore technically impossible, at least in a single timeshift file resp. buffer. Quote
erwin Posted October 13, 2009 Posted October 13, 2009 ...and PIDs are changing, as in most cases. Therefore technically impossible, at least in a single timeshift file resp. buffer. In TimeshiftPlus this is handled by a PID-replacement-management. mfg erwin Quote
peon Posted October 15, 2009 Author Posted October 15, 2009 (edited) Ok, ive tried timeshiftplus but it dosent work, on channel change it dosent keep the timeshift for old channel.. any other setting i should change? ....nm... well ive got it working now Edited October 15, 2009 by peon Quote
