Skipping advertisement
Mr. Man-wai Chang
IS there an add-on that could automatically skip commercials
(say, by detecting the disappearance of the TV station name at the upper right corner)?
There isnt any easy solution to this but look at http://www.kaashoek.com/comskip/
Comskip is an commandline utility to look for commercials in mpeg stream and to mark them. theres another tool "comclean" on the same page which should actually do cut them from the file.
Ive tried this tools and it need to br proerly and carefully adjusted to get good results.
Best regards, Piotr
