number of instances limit
derevo
i seem that the number of instances of DVBViewer is limited to 8.
i have 3 dvb-t tuners, 2 2 tuners dvb-s tuners and 3 one tuner dvb-s tuners.
in all 10 tuners.
i want to use different DVBViewer instance for each tuner for recording many radiostations simultaneously.
can I exceed this limit?
it is not convenient if i use many scheduler recordings.
one instance records all radio and tv channels to one hdd.
i want record to many.
how i can to run 10 instances simultaneously?
and using only one instance is unreliable.
if it crashs i miss all my recordings.
Edited by derevo
you can't you shouldn't. This is a major strain for your system and will never work reliable.
you can use different recording folders in the viewer itself or you can use the recording service, which would seem to be the best option.
