REQ: Imon software with Plugin mode
Im looking for the imon software with the plugin mode for using the DVBViewer with the remote.
The new version comeswithout the plugin mode.
Can anypone upload the software and send me the link?
Thanks
Mike
Not sure what you are referring to. Your Imon remote should work with DVBViewer without any plugin. I have no problem at all using the two together without any plugin. Just config the DVBViewer profile in Imon Manager under Settings---Program Command based on the settings you find in DVBViewer under Options---Input
That's right, a plugin is not necessary, since it responds to keyboard input, which was converted in the iMonManager software.
Little help, see link in my signature. ;)
