Recording service - Service will not start ?
tjn
I have installed DVBViewer Recording service on a Windows 7 64 bit.
But service will not start.
Log:
19.10.2009 22:24:09 Start App -----------------------------------
19.10.2009 22:24:09 thread service started
19.10.2009 22:24:09 StartService start timer
19.10.2009 22:24:09 Execute Couninitialize
19.10.2009 22:24:09 thread service ended
19.10.2009 22:24:09 End App -----------------------------------
Is recording services not compatible with Windows 7 64 ? What about Vista 64 bit?
Does the DVBViewer work there without problems?
DVBViewer starts up, but it is very unstable :rotfl::rotfl:
Is I posible to get the recording service to run on Windows 7 x64 or do you recommend Windows 7 32 bit, Vista 64 bit or maybee even old XP 64 bit.
It runs fine with XP 32 bit. But since my new pc has 4 gb of ram I would like to move to 64 bit if possible.
It is not a good idea to run on 64 bit platforms. Drivers made to 64 bit are often buggy. You have 4 Gb RAM, of which windows 32 bit can use it all, exept the amount used to Grahics card etc. This normaly result in 3 Gb. left for windows, more than you will ever need in a HTPC
