gucky Posted March 29, 2004 Posted March 29, 2004 can you program the DVBViewer, that the offset of the epg depends on the summer/wintertime ? http://www.DVBViewer.com/forum/index.php?s...?showtopic=3680 gucky Quote
Guest hackbart Posted March 29, 2004 Posted March 29, 2004 such a feature is already inside, but somehow i found a few satellites and transponders on astra, which can force a +12 hours shift. To avoid such a mess i disabled the automatic epg offset receive routine. Christian Quote
gucky Posted March 30, 2004 Author Posted March 30, 2004 no i mean NOT a dependence epg offset -> epg data on satelite. i mean a dependence epg -> local windows time? gucky Quote
Derrick Posted March 30, 2004 Posted March 30, 2004 According to the dvb standard, the time should be sent as utc in the corresponding table but that is not always the case. If it was, there would be no problem .. Quote
aydan Posted May 4, 2004 Posted May 4, 2004 UTC is Greenwich mean time right? This means there's no DST in UTC Now you have to set the EPG offset manually. So why not get the Offset from UTC from Windows? Bye Aydan Quote
