Fulco Posted October 22, 2009 Posted October 22, 2009 How do I move my DVBViewer installation to a new PC? I did install the software on the new system. But how do I get my favorites and channel settings to the other system? Fulco Quote
McenterFreak Posted October 22, 2009 Posted October 22, 2009 Start DVBViewer on the old PC Run DVBViewer Click About>Configuration folder Copy Favourites and Channels files to a media Install DVBViewer on the new PC Run DVBViewer Click About>Configuration folder Copy the files to this folder Before you do this, be shure that your recording hardware i installed, and working properly in DVBViewer Quote
Fulco Posted October 23, 2009 Author Posted October 23, 2009 Thanks! Why is the DVBViewer folder enclosed in folder CMUV? I was looking for a folder called DVBViewer in the ProgramData folder. Fulco Quote
Tjod Posted October 23, 2009 Posted October 23, 2009 Why is the DVBViewer folder enclosed in folder CMUV? CM&V is the company where you bought the DVBViewer Pro http://www.cmuv.com/04.html http://www.DVBViewer.com/en/index.php?page=impressum Quote
McenterFreak Posted October 23, 2009 Posted October 23, 2009 Forgot to write: Close DVBViewer BEFORE you paste the files, otherwise they might be owerwritten by DVBViewer Quote
