PLEASE DON'T MOVE: No webservice in recording services
tjn
HELP B)
I have a new PC with Windows 7 32nit, I want to run Recording Services.
The recodring service starts, but the Web interface is not up and running.
The PC has fixed IP address.
Snip from log:
24.10.2009 19:36:56 Start App -----------------------------------
24.10.2009 19:36:56 thread service started
24.10.2009 19:36:57 StartService start timer
24.10.2009 19:36:57 StartService create plugin list
24.10.2009 19:36:57 StartService loadchannellist
24.10.2009 19:36:57 TDVBDevice.InitDevice WinTV Nova-T Stick DVB-T Tuner (Dev1 Path0)
24.10.2009 19:36:57 Device Check present
24.10.2009 19:36:57 CheckDevicespresent start
24.10.2009 19:36:57 loadsetup load vcr
24.10.2009 19:36:57 TUniCastServer Could not listen: Error 10049 in function Bind
Address not available
24.10.2009 19:36:57 StartService load setup
24.10.2009 19:36:57 Recorderservice Enabled
Any idea?
This was working fine on me old Windows XP.
<entry name="UCInterface">192.168.1.7</entry>
<entry name="NIC">192.168.1.17</entry>
I think your IP for the streaming server is not setup correctly.
I think you are right. The correct is .17.
Where can I change it (.7 ->17)? In the configuration it IS .17
Found it in services.xml
Change the ip, but same problem :-(
Edited by tjn
On this page of the service configuration program.
Don't change the service.xml while the service is running. It won't work.
Strange: I stop the service. I change the IP address in services.xml. I start recording service again. And it changes the ip back up .7
Use the configuration program. don't mess with the file.
In the GUI interface the ip IS .17
24.10.2009 20:45:08 thread service started
24.10.2009 20:45:08 StartService start timer
24.10.2009 20:45:08 StartService create plugin list
24.10.2009 20:45:08 StartService loadchannellist
24.10.2009 20:45:08 TDVBDevice.InitDevice WinTV Nova-T Stick DVB-T Tuner (Dev1 Path0)
24.10.2009 20:45:08 Device Check present
24.10.2009 20:45:08 CheckDevicespresent start
24.10.2009 20:45:08 loadsetup load vcr
24.10.2009 20:45:08 StartService load setup
24.10.2009 20:45:08 Recorderservice Enabled
Looks better, but Webinterface is stillt not up and running :-(
Edited by tjn
:blush: Webservice is running, but nothing gets recorded :tongue:
EPG is working
Timer settings can be scheduled
While recording, status is recording.
TS-files gets created, BUT ARE EMPTY.
Strange problem.
Can anybody tell me why?
