ter9999 Posted October 25, 2009 Posted October 25, 2009 I have 2 suggestions wrt the popup channellist, please consider. 1. Add back the "Last Channel" option. This will improve user experience when in full-screen mode and only mouse is around. 2. Can group by only satellite besides of "Sat+Cat" and "Sat+Fre". Quote
ter9999 Posted December 20, 2009 Author Posted December 20, 2009 Also, it's better to allow change font size. It will be very useful when using HTPC. The default size is too small... Thanks! Quote
ter9999 Posted May 4, 2010 Author Posted May 4, 2010 bump for the suggestions... Can they be considered in 4.3 beta? Quote
ddlynm Posted September 2, 2010 Posted September 2, 2010 Also, it's better to allow change font size. It will be very useful when using HTPC. The default size is too small... Thanks! I completely agree. DVBViewer Channel List font is way too small when using as a HTPC on HDTV. It is also not friendly when it comes to selecting a channel. Too many clicks are required (Sat, Provider, Video, then finally the actual channel) to select a channel. I definitely would like a selectable font size(much larger). The channel list tree is entirely too cluttered for my taste. I would prefer a simple dropdown list with satellites to select from and then just open that single satellite in the tree list instead of having all of them cluttering the list at once. BTW, I care. These are some of the reasons that DVBViewer is not my go to HTPC application at the moment. Quote
Lars_MQ Posted September 2, 2010 Posted September 2, 2010 It's not meant to be used on a TV. use the OSD. Quote
