Per Raebild Posted October 26, 2009 Posted October 26, 2009 (edited) Does anybody know about timer conflicts? I have 2 tuners installed, in the manual i see that a red marked line means a clash in the timers, and the red will stay inactive until manual change of timing. However it dost happen in my timerlist, anybody knows what to look for? Thanks in advance Best regards Per Edited October 26, 2009 by Per Raebild
Tjod Posted October 26, 2009 Posted October 26, 2009 There is no simulation at the programing time. The timer will only be marked red. http://en.DVBViewer.tv/wiki/Webinterface_-...r#Timers_in_red If there is no device left an no device on the necessary transponder a Timer with a lower Priority will be stopped. If there are only timer with an equal or higher priority the timer will not start until a device is free. http://en.DVBViewer.tv/wiki/Timer_concept_...ervice#Priority
Per Raebild Posted October 26, 2009 Author Posted October 26, 2009 Thanks Newbie....sorry, I was wundering what i made wrong, because i tried to create 3 conflicting timer/recordings - however none of them is marked in red? (have 2 tuners, and it records fine) Best regards Per
Tjod Posted October 26, 2009 Posted October 26, 2009 You can record all channels from one frequency with one tuner. You have to make sure that the 3 timer are on different frequencies to test this.
Per Raebild Posted October 27, 2009 Author Posted October 27, 2009 You can record all channels from one frequency with one tuner. You have to make sure that the 3 timer are on different frequencies to test this. Okay, this is new to me - but will try it out and investigate a bit about this. In the meantime i discovered a problem with my system, it seems when i record 2 programs (have 2 tuners installed) the one of the recording file stays on 0 byte. This happend several times during timer recordings by today - do You have any hint/idea where to look for the solution? Best regards Per
