Blaukasten Posted October 28, 2009 Posted October 28, 2009 Hello, im experiencing a problem with the Technotrend connect-s2 3600 USB hardware concerning switching between different LNBs via DiseqC. Sometimes it is working but mostly switching from one channel to another requireing a different LNB results in "no signal". Switching back to the previous channel returns the normal signal again. Is this a known problem, do I have to install some additional software (I am using the DVBViewer pro), change some settings, or is the connect-s2 3600 simply not functioning properly? thank you for any hint! Gerhard Quote
Andrey123456 Posted October 29, 2009 Posted October 29, 2009 Try to reconnect all your cables. Try to replace all the parts tha you have spare e.g. cable, switch, connectors. Or just program DVBViewer to send DiseqC commands twice. Open Channel editor, in diseqC choose extended assign number to each LNB, perss edit. example http://www.orbita-sat.com/forum/attachment...mp;d=1254083884 Quote
Blaukasten Posted October 29, 2009 Author Posted October 29, 2009 Hello Andrey, thank you for your information, this sounds interesting. Unfortunately I dont have access to the link you provided. Could you please post the information here in the forum or tell me how to access the page (it is all in russian, so I dont understand it) thank you again Gerhard Quote
