Channel List in Recording service
McenterFreak
Hello
I can't figure out where Recording Service get its channel list from.
When i change the channellist in DVBViewer on the same PC where Recording Service is running, it is not reflected in the TV Guide in Recording Service. How can i force it to read the channellist in DVBViewer config. folder
Stop and restart the Recording Service.
I am having the same problem. I have tried restarting the service, and it still does not pull up the channel list correctly. In fact, it pulls up a completely different channel list, all in German, than that which DVBViewer uses. I am using Windows 7 64 bit. I am attaching the support.zip. Thanks in advance for any help.
In DVBViewer Pro you have the new channellist and in Recording Service the old one?
That is correct.
In the Recording Service web page, the correct channel list shows up on the SearchEPG and Timer tab. However, on the TimeLine and TVGuide tabs the old channel list (all German channels) appears.
Please tick in the web interface Configuration > Show channels without EPG
That did it! Thanks!
Now, how can I get it with EPG data? If I deselect the EPG option it goes back to the way it was before.
Edited by JoeH
Got it - just had to let the program finish downloading some more EPG data, and then it appeared. Works great. Thanks!
