HVR-4000 remote and DVBViewer
thecaptain2000
Hello The HVR-4000 remote seems to be a standard MCE remote, but how can I use it with DVBViewer? Is it supported as a MCE remote? (could not make it work) Is there an how to in how to make it work?
Thanks for your help
Did you enable the MCE 2005 remote in configuration?
Did you use the Learn function in the input section of configuration?
Does the ligth on the reciever blink when you press a button on the remote?
I found an MCE plugin but not an MCE 2005. Are they the same or are they different?
Sorry, but this stupid Forum software, cant hande (as far as i know) screendumps (if i try, it wants an URL, and my images is not in and URL location
But Settings>options>input plugins should give you the option to select MCE 2005.
After that you should be able to learn DVBViewer what it should do when you press a button on the remote
