EPG shows . instead of description
Bernd Wessels
I am using the DVBViewer in New Zealand. Everything is working fine but there is an issue with the EPG:
The EPG does only show descriptions for shows in the very future. The descriptions for shows in more than 2 hours future do only show the . character.
The problem is definetly not the NZ EPG. It works fine in ProgDVB and some other applications.
Is there a solution for this problem, or maybe a "refresh all EPG data" function?
Best regards from Auckland
Bernd
German Topic
http://www.DVBViewer.info/forum/index.php?...c=37238&hl=
Oh, I have a similar issue, except for me, shows for next 2 hours are just blank (no EPG data). Basically, when I run DVBViewer, and it shows EPG OSD on startup, there are programs in it, but few seconds later, they disappear and EPG window only shows programs from 3 hours ahead. Thought it was my DVB provider's fault, can't check it though, as I don't have any other TV application.
