HDHomeRun?
boborg
Will HDHomeRun work with DVBViewer Beta in Windows 7 ? - I can't find any channels when scanning DVB-c (Yousee - Denmark).
Strange - the new threads keep ending up here (sorry for the spam...)
Anyway, HDHomeRun will work with Windows 7 if u follow the above guide, but only with the beta version as stated.
Is it possible to limit the bandwith used when DVBViewer streams from HDHomeRun ?
DVBViewer use about 40Mbit/sec when viewing a normal channel where as MCE only use 6Mbit/sec.
No answer from the creators of the product ? I'm dissapointed - yes or no isnt that hard... :(
Well, after some reading and studying I think it should be possible. Are you willing to test it? I can't cause I don't have such a device. If yes I'll give it a try.
Yes I am willing to help, so your great product perhaps can be compatible with the popular HDHomeRun in future releases.
Feel free to contact me direct on my mail or via this forum.
My current systems are Windows 7 64bit, but I can make different Windows platforms without any problems if needed.
Best Regards
Peter
Edited by vizz
  • 9 months later...
Best Regards
Peter
I am also interested in buying the dual tuner (ATSC) one and in 64-bit W7 later on. Can I still use my old HDTV tuner cards, from 2005, with this external device with DVBViewer Pro?
So, any updates?
Edited by antdude
  • 2 months later...
Hi all,
new user of DVBViewer and hdhomerun
Running Windows 7 sp1 x32
HDhomerun firmware: 20110323
DVBViewer pro V4.6.0.1 - paid version
Provider: Yousee cable = dvb-c
My problem is that i can´t find any channels in DVBViewer when scanning
Transponder: kabel (QAM 64) 6875MS/s
Type: cable
Group: A
Fre start KHz 50500
Fre end Khz 85800
Free to air only
Hdhomerun software finds all the channels
DVDviewer can see the 2 tuners
Debug log:
09.04.11 13:55:46.417 Start App ----------------------------------------
09.04.11 13:55:46.417 Start App DVBViewer.exe
09.04.11 13:55:46.417 Start App 4.6.0.1
09.04.11 13:55:46.542 SetThreadExecutionState 0x80000001
09.04.11 13:55:47.702 TDVBDevice.InitDevice Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 13:55:47.702 TDVBDevice.InitDevice Silicondust HDHomeRun Tuner 1220057C-1 (2)
09.04.11 13:55:47.702 Device Check present
09.04.11 13:55:47.702 CheckDevicespresent start
09.04.11 13:55:47.702 CheckDevicespresent end
09.04.11 13:55:49.583 DevicePath \\?\hdaudio#func_01&ven_11d4&dev_1984&subsys_17aa20d7&rev_1004#4&2d854d6e&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rearlineinwave
09.04.11 13:55:49.584 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave
09.04.11 13:55:49.585 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 10
09.04.11 13:55:49.586 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 11
09.04.11 13:55:49.586 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 12
09.04.11 13:55:49.587 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 13
09.04.11 13:55:49.588 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 14
09.04.11 13:55:49.588 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 15
09.04.11 13:55:49.589 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 16
09.04.11 13:55:49.590 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 17
09.04.11 13:55:49.590 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 18
09.04.11 13:55:49.591 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 19
09.04.11 13:55:49.592 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 2
09.04.11 13:55:49.593 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 20
09.04.11 13:55:49.593 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 21
09.04.11 13:55:49.594 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 22
09.04.11 13:55:49.595 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 23
09.04.11 13:55:49.595 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 24
09.04.11 13:55:49.596 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 25
09.04.11 13:55:49.597 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 26
09.04.11 13:55:49.598 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 27
09.04.11 13:55:49.598 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 28
09.04.11 13:55:49.599 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 3
09.04.11 13:55:49.600 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 4
09.04.11 13:55:49.600 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 5
09.04.11 13:55:49.601 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 6
09.04.11 13:55:49.602 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 7
09.04.11 13:55:49.603 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 8
09.04.11 13:55:49.603 DevicePath \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\wave 9
09.04.11 13:55:49.672 LoadWindowDefs Loading WindowDefFile: C:\ProgramData\CMUV\DVBViewer\windowdef.xml
09.04.11 13:56:35.404 TDVBDevice.LoadSettings Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 13:56:35.405 TDVBDevice.LoadSettings Silicondust HDHomeRun Tuner 1220057C-1 (2)
09.04.11 13:56:57.247 Opendevice bvHomerun
09.04.11 13:56:57.248 TfrmScan Allocate Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 13:56:57.248 Start channelscan Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 13:56:57.255 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 50500 - Type: 0
09.04.11 13:57:01.077 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 57500 - Type: 0
09.04.11 13:57:04.627 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 64500 - Type: 0
09.04.11 13:57:08.181 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 71500 - Type: 0
09.04.11 13:57:11.735 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 78500 - Type: 0
09.04.11 13:57:15.536 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 85500 - Type: 0
09.04.11 13:57:19.324 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 92500 - Type: 0
09.04.11 13:57:23.126 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 99500 - Type: 0
09.04.11 13:57:28.540 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 107500 - Type: 0
09.04.11 13:57:33.864 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 114500 - Type: 0
09.04.11 13:57:37.664 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 121500 - Type: 0
09.04.11 13:57:41.209 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 128500 - Type: 0
09.04.11 13:57:46.530 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 135500 - Type: 0
09.04.11 13:57:50.600 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 142500 - Type: 0
09.04.11 13:57:54.380 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 149500 - Type: 0
09.04.11 13:57:59.697 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 156500 - Type: 0
09.04.11 13:58:03.461 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 163500 - Type: 0
09.04.11 13:58:07.523 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 170500 - Type: 0
09.04.11 13:58:11.346 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 177500 - Type: 0
09.04.11 13:58:16.670 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 184500 - Type: 0
09.04.11 13:58:21.987 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 191500 - Type: 0
09.04.11 13:58:27.314 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 198500 - Type: 0
09.04.11 13:58:32.682 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 205500 - Type: 0
09.04.11 13:58:38.009 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 212500 - Type: 0
09.04.11 13:58:43.334 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 219500 - Type: 0
09.04.11 13:58:47.401 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 226500 - Type: 0
09.04.11 13:58:52.726 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 233500 - Type: 0
09.04.11 13:58:58.049 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 240500 - Type: 0
09.04.11 13:59:03.390 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 247500 - Type: 0
09.04.11 13:59:08.718 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 254500 - Type: 0
09.04.11 13:59:14.055 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 261500 - Type: 0
09.04.11 13:59:18.133 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 268500 - Type: 0
09.04.11 13:59:21.959 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 275500 - Type: 0
09.04.11 13:59:27.297 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 282500 - Type: 0
09.04.11 13:59:32.618 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 289500 - Type: 0
09.04.11 13:59:37.960 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 296500 - Type: 0
09.04.11 13:59:43.304 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 306000 - Type: 0
09.04.11 13:59:48.679 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 314000 - Type: 0
09.04.11 13:59:54.030 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 322000 - Type: 0
09.04.11 13:59:59.366 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 330000 - Type: 0
09.04.11 14:00:03.147 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 338000 - Type: 0
09.04.11 14:00:06.979 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 346000 - Type: 0
09.04.11 14:00:10.827 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 354000 - Type: 0
09.04.11 14:00:14.937 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 362000 - Type: 0
09.04.11 14:00:18.748 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 370000 - Type: 0
09.04.11 14:00:22.572 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 378000 - Type: 0
09.04.11 14:00:26.361 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 386000 - Type: 0
09.04.11 14:00:31.719 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 394000 - Type: 0
09.04.11 14:00:35.310 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 402000 - Type: 0
09.04.11 14:00:40.630 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 410000 - Type: 0
09.04.11 14:00:44.204 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 418000 - Type: 0
09.04.11 14:00:48.022 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 426000 - Type: 0
09.04.11 14:00:51.839 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 434000 - Type: 0
09.04.11 14:00:55.658 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 442000 - Type: 0
09.04.11 14:00:59.445 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 450000 - Type: 0
09.04.11 14:01:03.199 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 458000 - Type: 0
09.04.11 14:01:06.973 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 466000 - Type: 0
09.04.11 14:01:10.824 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 474000 - Type: 0
09.04.11 14:01:16.165 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 482000 - Type: 0
09.04.11 14:01:20.190 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 490000 - Type: 0
09.04.11 14:01:24.294 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 498000 - Type: 0
09.04.11 14:01:28.065 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 506000 - Type: 0
09.04.11 14:01:32.131 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 514000 - Type: 0
09.04.11 14:01:35.917 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 522000 - Type: 0
09.04.11 14:01:39.672 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 530000 - Type: 0
09.04.11 14:01:43.432 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 538000 - Type: 0
09.04.11 14:01:47.458 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 546000 - Type: 0
09.04.11 14:01:51.490 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 554000 - Type: 0
09.04.11 14:01:56.828 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 562000 - Type: 0
09.04.11 14:02:00.620 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 570000 - Type: 0
09.04.11 14:02:04.442 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 578000 - Type: 0
09.04.11 14:02:08.228 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 586000 - Type: 0
09.04.11 14:02:11.998 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 594000 - Type: 0
09.04.11 14:02:16.028 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 602000 - Type: 0
09.04.11 14:02:19.803 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 610000 - Type: 0
09.04.11 14:02:23.391 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 618000 - Type: 0
09.04.11 14:02:27.263 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 626000 - Type: 0
09.04.11 14:02:31.057 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 634000 - Type: 0
09.04.11 14:02:36.402 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 642000 - Type: 0
09.04.11 14:02:41.739 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 650000 - Type: 0
09.04.11 14:02:46.858 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 658000 - Type: 0
09.04.11 14:02:52.202 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 666000 - Type: 0
09.04.11 14:02:57.524 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 674000 - Type: 0
09.04.11 14:03:02.870 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 682000 - Type: 0
09.04.11 14:03:08.205 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 690000 - Type: 0
09.04.11 14:03:12.289 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 698000 - Type: 0
09.04.11 14:03:15.872 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 706000 - Type: 0
09.04.11 14:03:19.460 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 714000 - Type: 0
09.04.11 14:03:23.096 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 722000 - Type: 0
09.04.11 14:03:26.677 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 730000 - Type: 0
09.04.11 14:03:30.503 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 738000 - Type: 0
09.04.11 14:03:34.102 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 746000 - Type: 0
09.04.11 14:03:37.667 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 754000 - Type: 0
09.04.11 14:03:41.525 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 762000 - Type: 0
09.04.11 14:03:45.387 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 770000 - Type: 0
09.04.11 14:03:49.218 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 778000 - Type: 0
09.04.11 14:03:53.056 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 786000 - Type: 0
09.04.11 14:03:56.630 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 794000 - Type: 0
09.04.11 14:04:00.442 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 802000 - Type: 0
09.04.11 14:04:04.288 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 810000 - Type: 0
09.04.11 14:04:07.859 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 818000 - Type: 0
09.04.11 14:04:11.702 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 826000 - Type: 0
09.04.11 14:04:15.284 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 834000 - Type: 0
09.04.11 14:04:19.126 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 842000 - Type: 0
09.04.11 14:04:22.699 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 850000 - Type: 0
09.04.11 14:04:26.513 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 858000 - Type: 0
09.04.11 14:04:30.338 TfrmScan Release Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:30.338 TfrmScan Destroy Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:30.628 TfrmScan Destroyed Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:45.378 Opendevice bvHomerun
09.04.11 14:04:45.379 TfrmScan Allocate Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:45.379 Start channelscan Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:45.386 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 50500 - Type: 0
09.04.11 14:04:48.997 TfrmScan Release Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:48.997 TfrmScan Destroy Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:04:49.473 TfrmScan Destroyed Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:11:36.319 Opendevice Silicondust HDHomeRun Tuner 1220057C-0 (1) did not start: bvHomerun
09.04.11 14:11:36.665 TfrmScan Allocate Hardware Open failed
09.04.11 14:11:38.275 Opendevice Silicondust HDHomeRun Tuner 1220057C-1 (2) did not start: bvHomerun
09.04.11 14:11:38.613 TfrmScan Allocate Hardware Open failed
09.04.11 14:12:07.806 TDVBDevice.LoadSettings Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:12:07.807 TDVBDevice.LoadSettings Silicondust HDHomeRun Tuner 1220057C-1 (2)
09.04.11 14:12:25.510 Opendevice bvHomerun
09.04.11 14:12:25.510 TfrmScan Allocate Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:12:25.510 Start channelscan Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:12:25.518 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 50500 - Type: 0
09.04.11 14:12:29.365 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 57500 - Type: 0
09.04.11 14:12:33.198 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 64500 - Type: 0
09.04.11 14:12:36.986 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 71500 - Type: 0
09.04.11 14:12:40.790 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 78500 - Type: 0
09.04.11 14:12:44.339 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 85500 - Type: 0
09.04.11 14:12:47.930 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 92500 - Type: 0
09.04.11 14:12:51.989 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 99500 - Type: 0
09.04.11 14:12:57.294 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 107500 - Type: 0
09.04.11 14:13:02.596 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 114500 - Type: 0
09.04.11 14:13:06.159 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 121500 - Type: 0
09.04.11 14:13:09.723 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 128500 - Type: 0
09.04.11 14:13:15.032 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 135500 - Type: 0
09.04.11 14:13:18.835 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 142500 - Type: 0
09.04.11 14:13:22.659 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 149500 - Type: 0
09.04.11 14:13:27.966 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 156500 - Type: 0
09.04.11 14:13:31.803 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 163500 - Type: 0
09.04.11 14:13:35.607 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 170500 - Type: 0
09.04.11 14:13:39.411 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 177500 - Type: 0
09.04.11 14:13:44.733 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 184500 - Type: 0
09.04.11 14:13:50.066 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 191500 - Type: 0
09.04.11 14:13:55.391 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 198500 - Type: 0
09.04.11 14:14:00.697 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 205500 - Type: 0
09.04.11 14:14:06.019 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 212500 - Type: 0
09.04.11 14:14:11.326 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 219500 - Type: 0
09.04.11 14:14:15.385 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 226500 - Type: 0
09.04.11 14:14:20.705 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 233500 - Type: 0
09.04.11 14:14:26.053 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 240500 - Type: 0
09.04.11 14:14:31.374 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 247500 - Type: 0
09.04.11 14:14:36.695 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 254500 - Type: 0
09.04.11 14:14:42.033 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 261500 - Type: 0
09.04.11 14:14:46.126 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 268500 - Type: 0
09.04.11 14:14:49.690 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 275500 - Type: 0
09.04.11 14:14:55.026 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 282500 - Type: 0
09.04.11 14:15:00.362 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 289500 - Type: 0
09.04.11 14:15:05.698 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 296500 - Type: 0
09.04.11 14:15:11.032 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 306000 - Type: 0
09.04.11 14:15:16.369 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 314000 - Type: 0
09.04.11 14:15:21.705 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 322000 - Type: 0
09.04.11 14:15:27.026 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 330000 - Type: 0
09.04.11 14:15:30.874 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 338000 - Type: 0
09.04.11 14:15:34.453 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 346000 - Type: 0
09.04.11 14:15:38.271 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 354000 - Type: 0
09.04.11 14:15:42.108 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 362000 - Type: 0
09.04.11 14:15:46.181 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 370000 - Type: 0
09.04.11 14:15:50.000 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 378000 - Type: 0
09.04.11 14:15:53.836 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 386000 - Type: 0
09.04.11 14:15:59.171 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 394000 - Type: 0
09.04.11 14:16:02.988 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 402000 - Type: 0
09.04.11 14:16:08.325 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 410000 - Type: 0
09.04.11 14:16:12.143 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 418000 - Type: 0
09.04.11 14:16:16.247 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 426000 - Type: 0
09.04.11 14:16:20.320 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 434000 - Type: 0
09.04.11 14:16:24.169 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 442000 - Type: 0
09.04.11 14:16:28.259 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 450000 - Type: 0
09.04.11 14:16:32.368 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 458000 - Type: 0
09.04.11 14:16:36.217 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 466000 - Type: 0
09.04.11 14:16:40.066 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 474000 - Type: 0
09.04.11 14:16:45.358 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 482000 - Type: 0
09.04.11 14:16:49.447 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 490000 - Type: 0
09.04.11 14:16:53.299 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 498000 - Type: 0
09.04.11 14:16:57.419 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 506000 - Type: 0
09.04.11 14:17:01.278 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 514000 - Type: 0
09.04.11 14:17:05.113 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 522000 - Type: 0
09.04.11 14:17:09.218 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 530000 - Type: 0
09.04.11 14:17:13.320 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 538000 - Type: 0
09.04.11 14:17:17.170 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 546000 - Type: 0
09.04.11 14:17:21.276 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 554000 - Type: 0
09.04.11 14:17:26.642 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 562000 - Type: 0
09.04.11 14:17:30.779 TDVBHardware.SetTuner PMT: 0 - SID: 0 - Freq: 570000 - Type: 0
09.04.11 14:17:35.089 TfrmScan Release Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:17:35.089 TfrmScan Destroy Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:17:35.424 TfrmScan Destroyed Silicondust HDHomeRun Tuner 1220057C-0 (1)
09.04.11 14:22:02.181 End App before OSD terminate
09.04.11 14:22:02.193 End App -----------------------------------
any idea ??
best regards
Dovenlas
  • 1 month later...
Hello,
I do have the same Problem! I own the new hdhomerun HDHR3-EU Tuner. It works well with eyeTV and it's own qiuckview Progamm.
Only the DVBViewer isn't able to find any stations.
Here you can see my Support.zip
I've noticed that the DVBViewer seems to recorgnize the tuner as a DVB-T device. But I can switch it manually to DVB-C (but without any change of the result).
Best regards Michael
Edited by Diablo_Vmax1200
  • 1 month later...
I have been a DVBViewer customer/user for years and I just bought the new (small) HDHomeRun. Cool product! Disapointed to learn that the best TV/PVR software out there does not work with HDHR - or has it been fixed?
