Record Menu has changed
majstang
Hi!
Dont know what i did to cause this, but the Record Menu does not look like it does on a new install of the DVBV 4.2.1.0. Im talking about the rightclick Record Menu.
It should look like this:
- Open Video
- Record Video
- Timer
- Recording Statistics
Instead it looks like this:
- Open Media file
- Record Video
- Recorder Window
- Recorder Statistics
Timer is gone but i can reach this window pressing Recorder Window.
Going to this window the After Recording options has changed as well.
Now i can choose between:
- Do nothing after recording
- Force shutdown after recording
- Force standby after recording
- Force hibernation after recording
- Close DVBViewer
- Start playlist
- Slumbermode
Instead of the usually:
- Nothing
- Shutdown
- Standby
- Hibernate
- Close DVBViewer
- Start playlist
- Slumbermode
The Options settings are default. Havent made any changes in configuration folder either, except for tweaking the min volume level.
Could someone shed some light over this and tell me what has happened?
