¿LIFEVIEW LV32T + DVBViewer?
zejio
I am thinking of buying this tuner:
LIFEVIEW LV32T PCI DUAL TDT HD MPEG4
I wanted to know if anyone knows if it is compatible with DVBViewer
Thanks!
  • 2 months later...
Right now I've seen this question ..
I have this card and no have problem with DVBViewer, run fine
Look my signature with my environment
Cheers
Cheers
Muchas gracias por la info!sabiendo eso creo que me la comprare ;)
¿va bien eso de la sintonizacion dual?¿funciona bien grabando un canal y viendo otro con DVBViewer?
p.d: también soy de barcelona :)
Nice to meet you
The card works fine in dual mode. You can recording/watching a channel while recording/watching another one.
I bought this DVB-T card in APPInfomatica, good price, search it in google. You can order the card tv in web and you can pick up it in one of three stores in Barcelona city.
Anything question else, send me a PM
Cheers
Edited by defcon5
I Know APP stores in Barcelona and I was know that card in the past because I was visit the APP website
Thank you again :)
  • 11 months later...
I'm also interested in buying this card (it's damn cheap), but what I intend to do is watching two different channels (from different transponders) at the same time (via DVBServer). Can you do that with this card?
Thanks.
Hi
When you are installing drivers, you can choose between 2 drivers, something similar to:
DVB-T Device or DBV-T Devices
I choosed DBV-T Devices
Cheers
