dull Posted November 8, 2009 Posted November 8, 2009 Dear Support, I upgraded to DVBViewer 4.2.1 but found that EPG in Chinese messed up in recording service Web interface. Thus, I uninstalled DVBViewer (cleared userdata folder) and reinstalled DVBViewer 4.1.1.1 and Recording Service 1.5.0.2. However, I got the following error when I watch TV for around 20 minutes. ======================================== Error in Userdata! Please install the DVBViewer with the correct data! ======================================== Please help. support.zip Quote
dull Posted November 8, 2009 Author Posted November 8, 2009 Is there a way I can download DVBViewer 4.1.1 or older version from http://www.DVBViewer.com/members/ ? Before I upgraded to 4.2.1 and then installed back 4.1.1.1, I think I was using either 4.1.1 or 4.1.0 without any problem. Quote
dull Posted November 9, 2009 Author Posted November 9, 2009 I followed recording service guide to set DVBViewer to use "Unicast Network Device", but it does not solve my "Error in Userdata!" problem. support.zip attached support.zip Quote
dull Posted November 11, 2009 Author Posted November 11, 2009 As I no longer have 4.1.1 setup.exe downloaded by my own account, I guessed I hit the same problem as in this thread: http://www.DVBViewer.info/forum/index.php?showtopic=36727 I guessed I have to stick with 4.2.1 and wait for future release that fixes Chinese EPG issue. Unless the author can put back 4.1.1 in Old Version section in member area. Quote
