plugin cant load pictures from NAS
mague
Hello,
i am curerently in contact with xice. He is author of the concinnity plugin. The plugin is a simple moviedatabase which loads <moviename>.jpg and <moviename>.txt to display them using the OSD.
The plugin cant load <moviename>.jpg and/or moviename.txt from network drives.
It works well on local drives like C:\ but not on networkdrives like \\T27-Media\share\
xice made a test on two PC's and wrote....
Wenn ich ein FileExists check mache, dann kriege ich ein true als wert.
Vielleicht können die Entwickler vom DVBViewer was dazu sagen.
