mhnyborg Posted November 9, 2009 Posted November 9, 2009 I have read this Installation: You need a working DVBViewer Pro 4.2.1.0 Installation. For this work with Admin rights. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your data folder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include •the exact steps to reproduce the problem. •the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions So now i got a folder with the name "copy of DVBViewer" with the beta files then what - rename the DVBViewer folder to "backup of DVBViewer" and then rename "copy of DVBViewer" to "DVBViewer" Is the beta working with dvblinkviewer? hope to get some help Quote
Devastation Posted November 10, 2009 Posted November 10, 2009 If you don't know ..... DO NOT USE THE BETA. .....not suitable for beginners. So now i got a folder with the name "copy of DVBViewer" I would rename this one to DVBViewerBeta. rename the DVBViewer folder to "backup of DVBViewer"No. Let it be DVBViewer.Create a shortcut to the Beta-"DVBViewer.exe" on your Desktop and also name it DVBViewerBeta. With that you can start the beta easily. Is the beta working with dvblinkviewer? DVBLink can cause problems not only with the beta, also with the full version.If its working on your system it should do it with the beta also. Quote
