Remote Desktop problem
albas
This might not be a bug, but I am posting it here since I have not seen any solution to this anywhere. If I schedule recordings and log in via remote desktop from another location (and same problem even if I disconnect the session)it creates and error when DVBViewer tries to start the recording. The program starts, but I an error saying "no hardware available". If I log back in via my normal desktop and restart DVBViewer everything works fine. Any scheduled recordings without interuption from remote desktop also works fine. Is there a workaround for this?`Here is another user with the same problem http://www.DVBViewer.info/forum/index.php?...=remote+desktop
Edit: I am running DVBViewer Pro, version 3.9.2.0
Edited by albas
  • 1 month later...
Of course: don't run an outdated version. You will get no support for it.
  • 4 weeks later...
Just wanted to give a heads up on this in case anyone else has the same problem: Upgrading to latest version of DVBViewer solved the problem :-) (guess I have to be better at upgrading software a little more often...). And thanks for a great software, upgrading also improved picture quality quite a bit.....
