Vlads Posted November 13, 2009 Posted November 13, 2009 I record every early-morning TV show, so I could enjoy it later with my morning coffee. Sometimes I forget to turn off my loadspeakers and recording this show wakes me up. In the previos version of DVBViewer there was an option to disable a/v. Now it is removed. How can I disable now a/v while recording from timer? Quote
Tjod Posted November 13, 2009 Posted November 13, 2009 It is disabled for all timer now. This means no timer recording Timer enables a/v any more at its start. Quote
Vlads Posted November 13, 2009 Author Posted November 13, 2009 It is not true. A/V is enabled in Timer - that's why it wakes me up in the mornings if I forget to turn off my loudspeakers. Quote
Tjod Posted November 13, 2009 Posted November 13, 2009 It is the seam behaviour as in the older version with a/v disabled. If you use the DVB Task Scheduler you have to activate "Restart DVBViewer Without Tunig Last Chennel" in the Task Scheduler. Quote
