Prof-7301
EnoSat
tested new HW - Prof Revolution DVB-S2 7301 PCI (8PSK/QPSK direct conversion tuner IC: STB6100 + Multi-standard advanced demodulator: STV0903).
On this HW work 16APSK transponders from 13 East (11334 H, 11373 H, 11432 V) but not stable (on this transpoders work simultaneous two mux)
Maybe added or fix this ?
..if you're referring to TransEdit's analyzer it's probably not possible if the mux rate is too high cos the tool always needs the entire mux. What happens if you perform a scan and then preview? Dunno whether hardware pid_filters are supported by this card.
