JordiV Posted November 15, 2009 Posted November 15, 2009 Hi I'm new, just bought the DVBViewer and can not find a way to finally make an ordered list of channels to my liking ¿that possibility is there and how is it done? thank you very much Quote
Devastation Posted November 15, 2009 Posted November 15, 2009 Go in DVBViewer Menu to ->Channel --> Channel editor Here you should have a entry like Astra 19,2 (example for german satellite). Rightclick -> expand tree. Now you can sort the channels by drag and drop. The channel on the first position has channelnumber 0! Then follows 1,2,3...... You must click and drag on the channelname not the symbol before. After sorting click on Save or ctrl+s. Quote
JordiV Posted November 15, 2009 Author Posted November 15, 2009 thanks and ¿there no other way faster? Quote
Devastation Posted November 15, 2009 Posted November 15, 2009 with some practice I feel its fast enough (if you dont need some thousand channesl be sorted). I've sorted only the channels I need (or thought I need). So about 50 entries. Quote
JordiV Posted November 15, 2009 Author Posted November 15, 2009 thanks and ¿there no other way faster? ok, thank you very much, although it would be one thing to improve,and create a more configurable channel editor type dvbdream Quote
RenkliArif Posted November 21, 2009 Posted November 21, 2009 Hello, I would like to expand on this question and ask two things: 1. Can we disable the sorting by provider so it's easier to drag/drop the channels? 2. How can we mix TV and Radio channels so I won't have to scroll all the way up for radio? Thanks for your help. Quote
