Start Dvbviewer hide
sentio
Hello everyone,
I use DVBViewer only for record channel.
Dont need graph, sound etc.
Is there way open DVBViewer hide mode like
" Shell("C:\Program Files\DVBViewer\DVBViewer.exe", AppWinStyle.Hide)"
i use com objects with .net ide and manage record on my program
thanks for help
Thanks but i have to use COM Interface
is there other way?
Hello,
try DVBViewer -x 8214
Untested though.
Look into Actions.ini. 8214 means "Hide VideoWindow". There are others like Hide Menu or Hide All. It should be possible to have multiple -x parameters on the commandline.
Hello
8214 doesnt work
I try desktop (32) and its work.
but i wish send app to tray menu
Thank you,
And can i change starting logo where it shows loading status osd creating windows, etc ?
or just hide startup screen
Edited by sentio
