slow to change channels (HD channels)
ardua97
yesterday in Italy and particularly in Lazio(an Italian region where I live)
I receive some DVBT channels HD (HD Canale 5, Italia 1 hd, hd rai)
I noticed a certain slowness in the channel change when I go on an HD channel
the sound begin after one or two seconds
the video takes about 8 seconds
as video card i have a sapphire HD4650 ULTIMATE 1GB HDMI PCI-E
as tv card i have a hauppauge hvr4000
as divx codec
video decoder: Cyberlink Video/SP Decoder(PDVD9 UPnP)
Render Video:EVR Vista EnHanced video render
I tried to ceckout the two voices
detects audio format
detects video format
and it seem to me that goes a bit faster
those two setting are usefull ?
there are thinks that i can do to make channel change faster
yes, two: the first is the one you have already setted while the second is to check "Settings / Options /TV+Radio / Fast Channel Switching" (in italiano: "Impostazioni / Opzioni / TV e Radio / Cambio Canale veloce").
The first setting check, at every channel change, the correct type of the audio/video stream to pass it to DirectX chain; unchecking this whoul lead sometime to a bad decoding of one of the two stream (it's depending on codec "flexibility"...); a "Rebuild graph" can correct this...
The second setting, when on, don't rebuild the graph on every channel change; as the first it can, sometimes, force you to manually rebuild the graph...
also thye secondsetting was already setted
comunque i canali hd si vedono bene
however the HD channels are seen well
and are few so when I want to follow along a transmission on one of those channels will go HD on channel
otherwise remain on those sd
as decoder Video H.264 i use Cyberlink H.264/AVC Decoder (PDVD7.x)
is this ok ?
Edited by ardua97
