mouhannadsl Posted November 17, 2009 Posted November 17, 2009 Dears I really disappointed with skystar hd2 it's working but picture freezing every 2~3 minutes for 1 second and then playing again on all channels Processor core2Due 3G/L2 6M MB MSI P45D3 Platinum VGA Nvidia 9800 1G RAM 4G DDR3 Hard 1TB / green buffer 32M Skystar hd2 with the latest driver 1.3 OS win7/x64 Codecs i use: Mpeg2 Cyberlink powerDVD9 hd Arcsoft Please and please advise me, i tried changing hardware reciever card, VGA card, RAM, POwer Supply but nothing do. I also tried windows XP/32 and 64 and nothing do. I'm waiting your kind support Quote
esackbauer Posted November 17, 2009 Posted November 17, 2009 Have you tried to set the Power Settings to a different scheme? to "Balanced" or "high performance"? Are there any background tasks? Which renderer do you use? EVR hopefully. Have you tried to reset the MB BIOS to default settings? Is there a MB BIOS update from MSI? Have you tried other Nvidia drivers? Does it happen only to SD channels or only to HD channels? Have you overclocked your MB? try not to do it. Quote
mouhannadsl Posted November 17, 2009 Author Posted November 17, 2009 My Dear I reset the BIOS and upgraded to the latest version I tried latest driver from MSI And latest driver from Nvidia I have no overclocked the CPU I used EVR the problem appears on all channels SD & HD Quote
Andrey123456 Posted November 18, 2009 Posted November 18, 2009 Check signal level. Are you using any third party plugins? Quote
