2 more practical suggestions
ter9999
I have following suggestions to improve user convenience:
1. Add vertical and horizontal shift(position) in "screen control" under "Input" in "Options".
Now there is vertical and horizontal shift(position) function implemented already. Hope can add vertical and horizontal shift(position) in "screen control" to allow users to assign shortcuts keys to them.
2. If can add an option that if EPG changes, it will popup on the screen. Just like the popup appeared when changing channels below.
Also, a small question: How can I recall the above popup? This only appear when changing channels. I searched in the "Input" list in "Options", there is no such control that I can assign a shortcut to this.
OSD-OK [Enter]
if you use TimeShift you have to add a input command for OSD-Show Miniepg (8207) or use the Tweak TimeshiftEPGdisplay.
http://en.DVBViewer.tv/wiki/Tweaks#TimeshiftEPGdisplay
OSD-OK [Enter]
Thank you very much! After setting following in setup.xml, it recalls successfully:
<section name="OSD">
<entry name="TimeshiftEPGdisplay">1</entry>
One other suggestion:
I use mouse middle key scroll to change picture zoom, hope when zooming, there will be a "zoom percentage" in the popup OSD box. This will be more obvious. This suggestion also applies to zoom presets #0, #1, #2 and #3.
  • 4 weeks later...
bump for the suggestions.... no one cares...
  • 4 months later...
Can they be considered in 4.3 beta? :bye:
