info bar
wikings1
1.hello i am trying to get upp the info bar but i dont know the name in the osd meny to get it upp
how do i get the info bra upp for 6 seconds from rcu.
2.i am using the deafault skin but is there any other cool skins
regards wikings1
2. There is a specific section in the "Member area" (where you dwld DVBViewer Pro...) and some other are spread in the forum: to reach most of them you can start from this german wiki page...
Please also notice that ther are 2 different kind of skins: for DVBViewer and for OSD...
thanks for that but question nr 1
i hope people now what i mean
the info bar whit clock channel signal etc
regards wikings1
As I see it what you mean is not in the OSD.
It is the statusbar.
Go to settings->options->input-> Section userinterface
and learn a button/key for "show statusbar". Then you can activate/deaktivate it. (Afaik S is learned for default)
Sorry, it's not absolutely clear what you mean, because i don't see a clock in the status bar :)
Or do you mean the Mini EPG?
You can get it up by pushing the Enter button.
Some settings regarding the Mini EPG:
Settings -> Options -> EPG/Teletext -> Auto Popup EPG Info (in seconds):
Input -> On Screen display -> OSD OK: Keyboard Enter
