geko67 Posted November 22, 2009 Posted November 22, 2009 Hi I have a problem with this card. I use a XP system S660USB card H-H 90-Usals-StaabO DVBViewer Pro 4.###### the last trans edit(test version) I have already used my dish from the begining with (USALS) a dreambox with no problem. Now i buy a dvb s2 card for use with PC and dish. 1. I MADE A CLEAN DRIVER INSTALL FOR DVB-S2 2.i made a clean instal of all codecs 3.I made a clean instal for the dvbV without channel list. Then -i download the new ini files, and i change them on the configuration folder/transponders and into DVB folder transponders. I put my coordinates on Positioner and i save the job. Then iv put angular position for all my preffered satelites (10-pcs-from 30w to 39e) I aplay and i save for all stelites First i scan my "zero"(16 degrees est) Iv scaned frecvencies for my interess then i export the file on a safe place. after i finished to scan all satelites i opened my dvbpro/channel list I imported all list of channels then i save them. I edited angular position for each satelite too. For now all ok! I close DVB then i started again. It play the la st channel. When i try to change from 16e to 1w-FTA to FTA the dish move but when reach the satelite wont open the cannel.I need to swich between 2 or 3 cannels to open. If i change to 1 w to 28,2 fta to fta-it happend the same thing. I read all hints from dvb manual(transedit) i use all 3.5 versions put with no results. I set manualy ( go to xx)-using position-but stii no efect. I can solve that? It is somthing who don't go !? Quote
geko67 Posted November 22, 2009 Author Posted November 22, 2009 (edited) It happend with all satelites not fot those. Changing between 13 to 8,8 changing before 4,8e to 30w. changing with 13 to 16 16 to 19 7e to 4.8 ...4.8 to 1 it seems it work. But if i set my favourites on sport 28.2-39 13 7 1- the sistem wont turn the dish when changing between far satelites. With dreambox work good. Edited November 22, 2009 by geko67 Quote
wikings1 Posted November 23, 2009 Posted November 23, 2009 i have the same issue but its not all time i offen go from 1 w ti 13 e thaiglobalnetwork channel (fta) den i need to zap some time i have the same card you have regards wikings1 Quote
geko67 Posted November 23, 2009 Author Posted November 23, 2009 I need to zapp too some channel on destination satelite then opened. But when i scan all satelites it works!!! It's a 22khz probblem? Or a voltage issues? Quote
Griga Posted November 23, 2009 Posted November 23, 2009 Or a voltage issues? Most likely yes. Or more precisely: A voltage and timing problem. TeVii devices usually switch LNB power off when they are not used. So when they get used again, they switch the LNB power on, but the DiSEqC switch / motor (or whatever is connected to the antenna cable) may need some time to power up, thus missing the first DiSEqC command, which comes too early. Possible workarounds (particularly by using the DiSEqC Editor) have been discussed here: http://www.DVBViewer.info/forum/index.php?...st&p=243613 Quote
geko67 Posted November 23, 2009 Author Posted November 23, 2009 (edited) Manny thanks Griga...but ...My tevii(my theatre) is a crap but when i change FTA to fta works grat. I dont know what y say but if the developper of DVB/transedit look on the repo can find the answer. it's weird...a crap works. It needs to made a quite control into transedit/DVB. It's not a driver probblem. I use the CD's drivers and aplication from tevii and tevii+"mycrap" recognize and work with USALS! Edited November 23, 2009 by geko67 Quote
geko67 Posted November 23, 2009 Author Posted November 23, 2009 (edited) Another thing: If i use transedit 3.5xxx, ticking on leftwindow an satelite-then Positioner>goto angular...-i wait i while then i select some frecvencies it work great. Dont matter who Satelite i tick if now i stay on 0,8w-i click to 39 e,goto angular.awaiting 30-40 secondes-then select frecv on right window it works too. I save this chlist(select all/add/update all/update/export to file) then i import them onto dvb, i save and reload , then i close dvb, and i restart again. BUT if i try to change fta-to fta between 2 satelites 13-19 19-28 4,8 7 the canells won't opened... i need to zapp on chanell list on a single satelite!! That's it's the point. it's a DVB probblrm! Edited November 23, 2009 by geko67 Quote
geko67 Posted November 23, 2009 Author Posted November 23, 2009 Now i think i found the trick... I try using zap from 0.8 w to 13 est and i seems it's work. i try tu put other channels lists to test again Quote
wikings1 Posted November 23, 2009 Posted November 23, 2009 please explain for me how to regards wikings1 Quote
wikings1 Posted November 26, 2009 Posted November 26, 2009 Geko67 can you explain what you did to fix the problem regards wikings1 Quote
