JordiV Posted November 23, 2009 Posted November 23, 2009 Hello I am of Spain,I have problem with DVBViewer, I have card hauppauge WinTV-HVR-1100 and has 2 frequencies of Tdt 706 Mhz, 730 Mhz, that thank you very much does not find channels me, what is problem?,thank you very much Quote
Gioxy Posted November 23, 2009 Posted November 23, 2009 what is problem?Can be many...Do you see other channels of the same type (SD or HD or whatever else...) on other frequencies? Do you see the channels you lack with other decoder? (take in mind that a top box decoder always have more sensivity that a PC card...) And, over all, please follow as strictly as you can the instruction of this post... Quote
JordiV Posted November 23, 2009 Author Posted November 23, 2009 Can be many...Do you see other channels of the same type (SD or HD or whatever else...) on other frequencies? Do you see the channels you lack with other decoder? (take in mind that a top box decoder always have more sensivity that a PC card...) And, over all, please follow as strictly as you can the instruction of this post... If that I see other channels, those of the other frequencies I see all but those them of the frequency 706 Mhz, 730 Mhz I do not see them in DVBViewer, in external a Tdt apparatus if I see all the channels of all frequencies,I must to raise the archives that to me the program generates supportool in this post? thank you very much again Quote
Gioxy Posted November 24, 2009 Posted November 24, 2009 (take in mind that a top box decoder always have more sensivity that a PC card...)ie PC devices have less sensivity...What are the singal and quality levels with the Tdt apparatus of those channels? And what about all others? My experience: on the same PC whit the same antenna with a Pinnacle DTT stick I cannot tune some frequency that instead works very well with Terratec DTT stick, ie every different type devices can have different curve of sensivity depending on the frequency, like a "frequency response" for Hi-Fi... Anyhow try to use Transedit (you can download it from the Members page) and use "analyze" to see what's the problem whit those frequencies, particularly with signal quality... Try also connecting the PC device directly to the antenna cable or to other antenna outlet... I must to raise the archives that to me the program generates supportool in this post?as you can see other channels it seems to me that this isn't a DVBViewer problem, so in this particular case it's most probably useless... Quote
