Can't stop EPG info file from being created
renzz
I have been using the recording service for ages now, but a few days ago had a play with the streaming and transcoding function. To do this, I installed VLC into the DVBViewer directory and all worked well. Subsequently I uninstalled VLC, but since then every recording I make has the additional EPG .txt file created as well, despite me having this option turned off ("Create EPG Information File"). If I turn that option on, the file is still created but I get the info in it twice. If I turn it off, it goes back to being created with the info in it once. It's like there is some other setting somewhere that has turned this on, but I can't find it.
Support.zip is attached - anyone any ideas where to look for this?
Thanks
