myRecordings suddenly empty
galmok
I am somewhat puzzled to find myRecordings empty all of a sudden. I have provided a Recorder path and that path holds numerous .ts files recorded by DVBViewer. I also added the same path to Movie VirtualPath where I also added a path to some AVI files. In Movie Thumbs I generated thumbnails which seemed to be working just fine.
But showing the myRecordings UI shows only an empty screen (i.e. no files are shown at all). And I just don't understand why...
Has anyone experienced anything similar? What could I have missed?
Oh, and when I record new stuff it also doesn't appear in the list. I have to play recording using File->Open... now. :-(
I looked in the MediaDatabase.db file and it seemed to contain all files, but I didn't check with a db tool. I renamed the file and let DVBViewer recreate the file and it is recreated with no files in it. So for some reason, DVBViewer fails to enumerate the files.
I have added the supporttool file in case anyone can use it to help me.
it seems somehow the decimal seperator is not consistend. The system saves it with a "," but wants to read it with a ".". The current beta does have a failsafe for these cases.
It seems all of the sudden your windows locale settings have changed... Wonder why...
Thanks! I did mess with the locale settings today because I couldn't get OpenOffice to use . as a decimal separator. I didn't think this would have affected DVBViewer.
I'll try the beta :blush:
