Bug: Chinese file name
jwcjwc
I use the Recording Service Web UI of Recordings list to delete old recordings
If I use Chinese file name
- the file cannot be delete
- the popup confirm window cannot display Chinese correctly
Edited by jwcjwc
Could you please post a file info (the txt file with the same name as the recording) as a zip here, so I can test it?
Attached is the file you required.
I also attached the WebUI that dose not display the Chinese filename correctly
Thanks!
test.zip
