Xtro Posted November 30, 2009 Posted November 30, 2009 I know there is a channel.dat in the DVBViewer folder, I added some channels to this one with TransEdit but when I loaded the file with Channel Editor 1.51 to organize it better it didn't see any changes. In DVBViewer the changes are OK. Also is possible to use another editor if I convert the channels.dat? I like the editor of Humax receivers, it's very quick to sort it out by provider or country. Do you know of a good channel editor? Quote
Tjod Posted November 30, 2009 Posted November 30, 2009 The channel list is stored in the channel.dat in the configuration folder. http://en.DVBViewer.tv/wiki/Configuration_folder Quote
Xtro Posted November 30, 2009 Author Posted November 30, 2009 Thank you very much, also do you know a good editor that is compatible with DVBViewer and can sort by provider, see frequencies, etc? Quote
Tjod Posted November 30, 2009 Posted November 30, 2009 You can export the channel list as .csv (Channel list Editor > the second icon at the bottom) and use Excel or Calc to edit it and if you save it as .csv you can import it into DVBViewer. Quote
Xtro Posted November 30, 2009 Author Posted November 30, 2009 Thank you again, this will do the trick Quote
