Unicode EPG import using COM
Delphi
From another thread about HTTP interface:
If you consistently save the whole stuff as unicode and set the charset = 255 it will should work...
I tried this with the Pro version of DVBViewer: Any strings containing Danish characters æøå was compleatly ignored.
Then I tried the 4.3.1.45 beta: æøå was displayed as chinese characters (at least I think it is :bye:)
Unfortunatly this cannot be tested with the current official version of Xepg since I found a bug in that one. Setting Charset to OEM_CHARSET, which should be 255 actually set it to 16 (Index in ComboBox). Forgot to look up the real value in an array o:)
If you or anyone else want to test you can download a newer version here:
http://www.a123.dk/forum/setupxepg.exe
Be sure to have the following settings:
XMLTV Job Editor: Charset: Use OEM_CHARSET
Options -> Technical -> Uncheck "Import as ANSI into Recording Service" If you want to test UTF-8 import.
Options -> Technical -> Check "Flag XML Import into DVBViewer as UTF-16"
You will se some new controls. You can play around with them, but this stuff is under construction and will have no effect.
Edited by Delphi
In the next beta... It will not work now.
Great o:)
It would be really nice to remove all these options about Charset and encoding. Well, maybe I should leave them for a while and publish a test version when the next DVBViewer beta is out.
