RenkliArif Posted December 2, 2009 Posted December 2, 2009 Hello, I'm using DVBViewer for a while now and I have one annoying issue. I use a TechnoTrend S2-3200 with 5.0.2.1 drivers. I have it connected to a diseqc that's connected to Türksat 42E and Eutelsat W3A 7E. The problem is as follows. When I zap through the channels the Eutelsat channels sometimes will not show up. The signal bar shows and all, but the channels won't show in any way. When switching it takes a bit longer (2 seconds or so) for the OSD to show up, but the screen stays blank. The only way to ''fix'' this is to restart DVBViewer a few times. Is there a way to make DVBViewer zap through the channels so I won't have to restart it all the time? This behavior happens randomly and I can't reproduce it myself. Thanks for your help. support.zip Quote
Griga Posted December 2, 2009 Posted December 2, 2009 Have you already tried Options -> Hardware -> Retune on missing stream after... ? Quote
wikings1 Posted December 2, 2009 Posted December 2, 2009 i putted 1 second and its fixes the problem when zapping and its not showing the shannel http://www.DVBViewer.info/forum/index.php?showtopic=37620 thanks wikings1 Quote
RenkliArif Posted December 3, 2009 Author Posted December 3, 2009 Unfortunately that just leaves me with a not loading channel with a star next to it e.g. Star TV* instead of just Star TV. What I find fixes the problem is if I click Rebuild Graph a few times. Quote
Griga Posted December 3, 2009 Posted December 3, 2009 * means encrypted data. Seems your CAM doesn't work as it should resp. needs several attempts. Quote
RenkliArif Posted December 3, 2009 Author Posted December 3, 2009 I'm using some generic CryptoWorks CAM (DVBShop is dead, I can't link to it) I don't think it's a CAM problem, since FTA channels on that satellite won't open sometimes either. Quote
wikings1 Posted December 5, 2009 Posted December 5, 2009 maybe its both Have you already tried Options -> Hardware -> Retune on missing stream after... ? u putted 1 sec and my problem is gone Quote
RenkliArif Posted December 5, 2009 Author Posted December 5, 2009 Yes, I have. It just stays there doing nothing Quote
