Barleyman Posted December 6, 2009 Posted December 6, 2009 Should I set duration for the autosearch timer. What does it actually do if I do? If I make it 0:01 to 23:59, does that mean the autosearch timer is running all the time OR it runs once at 0:01 and the timer is not updated before next day? OR the duration is completely irrelevant and autosearch will run every time EPG data is updated?
Lars_MQ Posted December 6, 2009 Posted December 6, 2009 The autosearch timer will end, when the autosearch has ended. The duration will be ignored.
Barleyman Posted December 6, 2009 Author Posted December 6, 2009 The autosearch timer will end, when the autosearch has ended. The duration will be ignored. 'Kay. Restarting service seems to run the timer also.
Lars_MQ Posted December 6, 2009 Posted December 6, 2009 just set the duration of the timer to 1 minute.
