Georges Valch Posted December 7, 2009 Posted December 7, 2009 Im working at an OSD skin and I want to put a signall strenght metter (like in sysinfo progressbar) on MyMiniEPG window. Someone could help me pls? Because when I try to reproduce that one I have no color. Thank you and sorry because I dont speak german. Quote
SnoopyDog Posted December 12, 2009 Posted December 12, 2009 Hi! No, this is not possible! Try to find and download the program "dvbvspy.exe" and click on "GetTags", then you will see all global variables that are available by default on specific OSD pages. Other information is available only in the page where they are intended to be displayed. E.g. in "mysysinfo.xml" the progress control with the ID 52 and and a label with the ID 51 will be filled with the information you need. On other pages different control IDs may be filled with different information. This depends on the context of the page. Quote
Georges Valch Posted December 13, 2009 Author Posted December 13, 2009 Thank you, SnoopyDog. I thought that noone will answer me but finally u do it . Well, if its how u said and Im sure it is, thats very frustrating... but thats it. At least pls tell me how I could launch mySisinfo.xml page not from osd menu but pressing a button on my remote? Thx again man, have a nice day. Quote
evgen_ln Posted December 13, 2009 Posted December 13, 2009 (edited) Some time ago I wrote a small plugin, it exports such variables: # Miniepgvars.SignalStrength - signal level (updated every 1 sec); # Miniepgvars.SignalQuality - quality (updated every 1 sec); # Miniepgvars.HDlogo - possible values: HD_1080p_Video.png, HD_1080i_Video.png, HD_720p_Video.png; # Miniepgvars.Channel_Root ; # Miniepgvars.Channel_Category; # Miniepgvars.Sat_Position - position of the satellite; # Miniepgvars.Transponder.Frequency, # Miniepgvars.Transponder.Polarity, # Miniepgvars.Transponder.Smbolrate - frequency, polarization, symbol rate of the current transponder; Limitations: # Miniepgvars.SignalStrength, # Miniepgvars.SignalQuality obtained for the first found hardware (DVB File Device, PTV Network Device, Unicast Network Device, Multicast Network Device excluded, when installed more than two cards may not correctly receive data. Unfortunately I do not know other way). I understand that this is not the most elegant way but it works Edited December 13, 2009 by evgen_ln Quote
Georges Valch Posted December 17, 2009 Author Posted December 17, 2009 Some time ago I wrote a small plugin, it exports such variables: # Miniepgvars.SignalStrength - signal level (updated every 1 sec); # Miniepgvars.SignalQuality - quality (updated every 1 sec); # Miniepgvars.HDlogo - possible values: HD_1080p_Video.png, HD_1080i_Video.png, HD_720p_Video.png; # Miniepgvars.Channel_Root ; # Miniepgvars.Channel_Category; # Miniepgvars.Sat_Position - position of the satellite; # Miniepgvars.Transponder.Frequency, # Miniepgvars.Transponder.Polarity, # Miniepgvars.Transponder.Smbolrate - frequency, polarization, symbol rate of the current transponder; Limitations: # Miniepgvars.SignalStrength, # Miniepgvars.SignalQuality obtained for the first found hardware (DVB File Device, PTV Network Device, Unicast Network Device, Multicast Network Device excluded, when installed more than two cards may not correctly receive data. Unfortunately I do not know other way). I understand that this is not the most elegant way but it works Thank you evgen_ln, your plugin was exactly what I need it for my skin. I dont plan to use DVBViewer with more than a card so ur app works gr8. thx again man. Quote
mague Posted December 17, 2009 Posted December 17, 2009 Some time ago I wrote a small plugin, it exports such variables: # Miniepgvars.SignalStrength - signal level (updated every 1 sec); # Miniepgvars.SignalQuality - quality (updated every 1 sec); # Miniepgvars.HDlogo - possible values: HD_1080p_Video.png, HD_1080i_Video.png, HD_720p_Video.png; # Miniepgvars.Channel_Root ; # Miniepgvars.Channel_Category; # Miniepgvars.Sat_Position - position of the satellite; # Miniepgvars.Transponder.Frequency, # Miniepgvars.Transponder.Polarity, # Miniepgvars.Transponder.Smbolrate - frequency, polarization, symbol rate of the current transponder; Limitations: # Miniepgvars.SignalStrength, # Miniepgvars.SignalQuality obtained for the first found hardware (DVB File Device, PTV Network Device, Unicast Network Device, Multicast Network Device excluded, when installed more than two cards may not correctly receive data. Unfortunately I do not know other way). I understand that this is not the most elegant way but it works Hello evgen_ln, and why did you hide this gem for so long ? Do you want to release the sources ? Public or by PM. Quote
evgen_ln Posted December 17, 2009 Posted December 17, 2009 (edited) Not sure, but it looks like the latest source code. Edited November 28, 2011 by evgen_ln Quote
evgen_ln Posted December 17, 2009 Posted December 17, 2009 (edited) Sorry, I can't correct the previous post, so correctly link Edited November 28, 2011 by evgen_ln 1 Quote
mague Posted December 30, 2009 Posted December 30, 2009 Sorry, I can't correct the previous post, so correctly link Thanks a lot Quote
Siggi0904 Posted October 11, 2010 Posted October 11, 2010 Hello evgen_ln, is it correct, that you plugin blocks the DVBViewerServer for other applications? Can you correct or fixe that? I try to run a command-line skript wich try to read things from the DVBViewerServer. Thanks. Quote
rafal82 Posted October 14, 2010 Posted October 14, 2010 can somebody released by his miniepg I wanted to use up items in his mniepg I was very grateful Quote
mohammad izadpanah Posted July 8, 2018 Posted July 8, 2018 Hi freinds Please send the link source of Miniepgvars plugin. thanks Quote
mohammad izadpanah Posted July 8, 2018 Posted July 8, 2018 (edited) Double post!please delete Edited July 8, 2018 by mohammad izadpanah Quote
mohammad izadpanah Posted July 8, 2018 Posted July 8, 2018 On 12/18/2009 at 12:24 AM, evgen_ln said: Sorry, I can't correct the previous post, so correctly link Please resend the link source of Miniepgvars plugin. Quote
