raty Posted December 11, 2009 Posted December 11, 2009 I have found that my recording service has stopped recording video. I get sound but no video??? If I set to record the whole transponder I get exactly that, all audio and all video?? The debug log shows nothing odd except the data rate is 0.03MB/s rather than 0.3Mb/s. Indicates that it is just recording the audio tracks. Can anyone suggest what may have gone wrong?
raty Posted December 11, 2009 Author Posted December 11, 2009 I have no CAM. I will check that the hardware config has not got corrupt though.
MaxB Posted December 11, 2009 Posted December 11, 2009 Which Recording Format (*.ts, *.mpg or Audio) do you use?
raty Posted December 29, 2009 Author Posted December 29, 2009 I have found that this corrected itself when I re-installed the recording service and then ran the latest Beta version over it again. However, I still get the odd recording that only records the audio. And I only record as the original TS stream. The recording logs do not show any errors. There does not appear to be a debug entry that indicates whether audio and/or video is available and being recorded?
