No Cyrillic symbols in OSD
mak73
Sorry if it was already discussed here.
I have a problem with Cyrillic chars in the OSD default skin. Cyrillic file names show up with strange chars. Apparently the appropriate font is missing. But this is not the biggest problem. It cannot play the files with the Cyrillic names. It says "Cannot render Mediafile/Output Pin, error: 0x80070002 The... stem cannot find the file specified."
Any suggestions?
Windows Vista Ultimate x64
DBViewer 4.2.1
Edited by mak73
The unicode support is currently only in the Beta version of the DVBViewer.
Thank you for the prompt reply.
Actually the program not necessarily should support Unicode to support Cyrillic chars. Cyrillic chars are 1 byte. This is just a matter of codepage. Anyway I hope the issue will be resolved within the Unicode support.
Edited by mak73
