newcredo Posted October 3, 2002 Posted October 3, 2002 hi, I'm using version 1.8 and I'm quite satisfied... for sure I will pay for having the new features of the commercial version. I use DVB.viewer with a cordless keyboard, so that I can change the channels far from my computer, sitting and directly seeing the images in front of the TV. Whit this actual version I can olny save my preferred 10 channels on keys 1-10 of the keyboard...and it's a real limitation...! Why don't enlarge this possibility using keys 1-10, Shift 1-10, Ctrl 1-10, Alt 1-10 and AltGr 1-10... in this way it will be possible to memorize 50 channels... I think this implementation is very "easy" to realize... so I hope I will have this very good feature on the new versions... All the best Bye Marco Quote
Guest hackbart Posted October 3, 2002 Posted October 3, 2002 I'm glad to tell you that i slighly modified the favourite list; well it is actually existant, but you can now also change each channel like on a tv: It is now possibly to enter a number up till 9999 to change the channel. A small information which channel will be tuned in is also displayed on the osd. Christian Quote
newcredo Posted October 3, 2002 Author Posted October 3, 2002 so Ok, I will wait for the new release... and I will let u know thanx Quote
