ordinary73 Posted April 14, 2004 Posted April 14, 2004 Hi I would like to have the Volume-Slider centered on the bottom of the Video-Screen (like the EPG-'NowPlaying' overlay) because the Volume-Slider is not fully visible if the Screen is zoomed out. Thomas Quote
Guest Oliver Posted April 15, 2004 Posted April 15, 2004 Insert these settings into the Setup.ini and try them: [OSD] AspectX= AspectY= TeletextPosX=20 TeletextPosY=20 ChannelPosX= 10 ChannelPosY= 8 RecTipX= 10 RecTipY= 10 GaugePosX= 10 GaugePosY= 8 Gauge should be the volume control. You must also set the Aspect X and Y. Bye, Oliver Quote
Guest hackbart Posted April 15, 2004 Posted April 15, 2004 yupp AspectX and AspectY are floating point values and responsible for the osd size. If both are 1.0 you have the same osd size like video. Christian Quote
