DVB Task Scheduler under Win7 available !
ratus69
Hi there,
I don't know why but I've never seen an upgrade for DVB Task Scheduler under Win7
The task manager works differently with Win7 (same as Vista ?)
So I have developped a program to create or delete a task to awake the pc several minutes before a program is scheduled in DVBViewer
Image of the program
The program is in french and works fine but I will need an english beta tester to test it because I use a routine that use a french keyword and I would like to make an universal program working with any language
You can PM me if you are interested
Thanks
sounds really interesting and could probably help me to overcome an issue. Unfortunately I'm not native English speaker.
Edited by Mandrax
